Originally posted by NewBlackDak
wow, you're brave to use 2.1v on a crapcano!
Originally posted by Shapeshifter
you don't have it stable at over 3ghz do you?!
I don't think Ive even seen a stable 2.9...
if it is stable, give some benchie pics
Originally posted by Mag Master
how much do you want for it?
I can trade my 2.4+ 2500+ for it and some cash also.. I NEED one of these chips..
Originally posted by Stang Man
heh, try 2.2 , i've even done 2.3 (max) but board doesn't like that too much.
nice clocking Dude
Originally posted by CrimandEvil
I hope you thrown some heatsinks on those mosfets!
Originally posted by Dude
These mobiles will make you do stupid shit man! It's gotten to 50 under Prime @ 2700. That's not too bad I think. BTW, I know this question has been asked before, but as long as the temps are under control, high volts should not be a problem? Or is that a fallacy?
I think the honor achieved with that oc is called "boots into windows at 3ghz yadayada"Originally posted by boshi
stang_man, stop posting those pics of speeds your CPU isnt stable at without mentioning that they are not in fact stable, and just hoping that nobody will ask. I could show you one of my 1800+ @ 2.4, but it would crash bad soon after. If it isnt stable, it doesnt count.
Originally posted by wayne
either its a wonder or he used photoshop....lol
ouch! man, Id imagine you might see a bit more with the antec, but 2.1!!! man toss a sp97 on that thing with a really good 80mm fan =
If I remember right some site was reviewing either a Thermalright or a Swiftech HSF and had some numbers comparing them to a WC setup. I have to review somewhere in my bookmarks, I could dig it up for you. Either way it is possible to cool a chip on air to with in a few degrees of a WC setup.
Here they are:
Danger Den RBX
SLK-948U and SP-94
Swiftech WB and HSF comparison
Okay there wasn't one specificly with the SP97 but there are enough that I think you can cobble together what the difference might be.
