Excellent!
I have been staring at my brand new G5 case for months, trying to decide how to proceed.
Like you, I am hestitant about taking the easy way out with a standard mobo tray (although I did acquire a Lian-li tray just to look at).
If you don't mind, I have a few questions...
-To remove the LH (mobo) side panel, do you really have to undo the two zillion fasteners all around the case edges?
-Is that sidepanel double layered? The standoffs are swaged into the inner surface but I don't see any traces of the process on the outer skin.
-What kind of screws is Apple using? None of the Torx bits seem to fit very well...in fact, none of my normal bits seem a good fit.
Any info appreciated and good luck with your project.
