Well, was at court today and finally won out against the PC seller who ripped me off by taking my money and never deliverying my goods!
I now have the go-ahead to get some parts from Scan and this time, I'm gonna put it together myself because I should be able to figure it out and I've done OS installs from scratch before.
Anyhow, before I order I wanna get some help in deciding between a couple of components.
First up, motherboard, torn between
BFG 680i
aBit iP35
aBit X38 (though only from Scan as I'm not trusting Yoyotech after their recent virus incident
Processor I'm pretty happy with an E6750 or E6550 depending on how much I spend on other bits
Graphics card, it's a toss up between the 8800 GTS 320Mb version or the HD2900 Pro, as much as I'd like an 8800GTX there's little point without spending £300 on a monitor and I'm now saving for my wedding next year! Only real choice between the two depends on the motherboard, if I get the X38 mobo, I'll get the HD2900 Pro so I can go Crossfire later on.
PSU is no contest, the 620w Corsair to make sure I'm opperating right around 50% load at worst case scenario.
Operating system, I'm tempted to get both XP Home and Vista 64bit Home Premium, so I can use both, though there's an arguement for putting Linux as my second OS and saving some money here.
Other main area I'm confused about is monitor, looking at a couple of choices here
HP W2207 22" - seen these in the flesh and I like the finish though not sure about glare from the patio.
HP W1907V 19" Similar to the one above, but smaller, £70 cheaper and missing the digital input, do I loose much without having a digital input?
20.1" Dell E207WFP - Seems a reasonable compromise on price and size, used to Dell monitors as we have a lot at work.
So, any other suggestions? All in all, I'm aiming to spend about £800 on the PC, £200ish on the monitor plus picking up a cheap Freecom NAS. Already have the case for this, a Lian Li PC-A05 as it was the perfect size to tuck neatly under my desk without worrying too much about cooling issues due to it's front to back airflow.
BFG 680i
aBit iP35
