Yet another C2D rig
Elemental
Well, I figure there are a million threads about this, but I did a little searching and couldn't find specific answers to the questions that I have. Anyways, I am planning on upgrading my computer a bit, since my s939 is showing its age. Plus I want dual core. :cool:
I am on a bit of a budget, so here are the components that I have in mind:
Gigabyte GA-965P-DS3
Link
Intel Core 2 Duo E6300
Link
Kingston 1GB DDR2 667 Memory x 2
Link
Arctic Cooler 7 HSF
Wherever is Cheapest
I already have case, power supply, optical, hard drive, video card, etc.
Questions:
If I wanted a mild overclock of the E6300, from lets say the stock 1.86ghz to 2.0ghz or 2.2ghz, would I be able to attain it with the the air cooling and the setup above? I think I might need faster memory? I know the clock multiplyer is 7, but I have no clue on the FSB or the speeds of the new fangled DDR2.
The second question is that on newegg, they have two motherboards listed for the DS3, the above GA-965P-DS3 and the GA-965G-DS3. The only thing the GA-965G-DS3 adds (besides cost) is on board video, correct?
Please pardon my ignorance, the last time I overclocked was when I ran a 1ghz Athlon at 1.2ghz with a screaming delta fan and PC133 memory, and I have had no experience since then. Thanks in advance!
If you're looking at two of those memory modules you'll spend $140. You're better of spending a little extra money and getting something like the Corsair DDR2 800 modules for $169 after rebate.
http://www.newegg.com/Product/Product.asp?Item=N82E16820145590
The processor is running at 7 x 266 = 1862. You'll have to up the fsb so I would think higher quality ram is the best bet.
People are getting the E6300 well over 2.2 easily with air. Take a look below to see what other people have obtained. The C2D seems to be an overclocking dream.
http://www.hardforum.com/showthread.php?t=1138241
AT got the E6300 to 2.6Ghz on the stock intel cooler: http://anandtech.com/cpuchipsets/showdoc.aspx?i=2802&p=2
Like cb9fl said, you're better off goin with some DDR2-800 sticks or OC'ing those 667 sticks (though I dont know how well they OC).
2.2Ghz / 7 = 315Mhz FSB => DDR2-630
DDR2-667 = 333Mhz FSB => 7 * 333 = 2.33Ghz
DDR2-800 = 400Mhz FSB => 7 * 400 = 2.80Ghz
The difference between the GA-965G-DS3 and the GA965P-DS3 is the chipset. The G965 Express has the intel integrated GMA X3000. This limits the overclockability of the chipset/motherboard. Go with the GA-965P-DS3 instead. The P-DS3 can reach 500+ FSB (500*7=3.5Ghz).
ewiz.com has the freezer 7 pro for $20 before tax and shipping.
I'm running an E6400 @ 8 * 400 with only +0.05 vCore, and its rock solid. I used a Scythe Ninja Plus Rev.B, so it idles at 30° and reaches 50° on load. (GA-965P-DS3 F7 BIOS // E6400 @ 1.33125vCore // 2gbnq @ 1.8vDimm)
So I can technically still use DDR2 667 memory, but it would limit the amount I am able to overclock to 7x333 = 2.33Ghz? Or is there another factor in the memory choice that I am missing?
I really do not plan to push the hardware much at all, because I enjoy having a cool, quiet, and stable computer that I do not have to worry about.
Well, you can OC the memory as well, but OCing cheap memory can be a pain and sometimes you will get no where so if you want to OC more, you should get ddr2800 as it is guaranteed to run at 400FSB (since it is ddr2800).
Just remember that OCing is case by case. My e6400 will only do 2.8ghz without dumping a crapload of volts into it.
I see, but I really was only shooting for 2.0-2.2ghz. Nothing fancy, at least for now. So to get 2.2ghz, I would not need to overclock the memory, as it is able to do 2.2ghz below stock memory frequencies, correct?
I guess the moral of the story is I will inevitably want to push it faster and the faster ram will assist me in that? :D
Yes... Yes.
