Yup! You guessed it! Another one of these!
I HAVE researched alot on these boards but still deciding. (HATE these buying decisions!)
Anyhow, i am planning on upgrading my current 2-3 year old setup to something a little more recent in the very near future. Going to keep a few things, but may replace some of them if the general consensus suggests it. Anyway, here is my current setup:
AMD X2 4800+
2 GB Corsair 400 ram
Asus a8n sli motherboard
7800 gtx 256 mb
19" sony lcd monitor
Black v1000 lian li case
Vista OS
630w psu
X-fi platinum
My current rig is pretty decent still but is really starting to bog down hard on more recent apps and games.
Proposed build:
Q6600 quad cpu
Evga 680i motherboard
2x 2gb Ram
Evga 8800 (most likely a GTX)
I know that the 6600 will be even more cheaper in the 3rd quarter but it will be at a decent price for me this next price cut. Plus i want a quad core system and this seems to be the best bang for the buck atm once the price cuts are in.
I will mildly OC so i figure the 680i board will be ok according to the reviews i've seen on it.
Memory i'd like something that's decent and be able to OC a little if i want. Reccomend if you know any good 2gb stick makers. (corsair or pny?)
The 8800 i'd like to get an OC edition and possibly step up if the newer versions come out in the next 90 days after purchase. I figure there will be a decent chance if i order in a week or two on this stuff. Considered a 640 GTS, but would rather get a better model unless the real world difference is pretty negligible. (will wait a week or two or three if they are cutting prices soon on the cards tho)
Getting a real good deal on a dell 2405 so that point is covered.
I figure the 630 watt psu should be ok until i decide to add in another card in the future.
As long as everything fits in the V1000 i'll keep that or upgrade to a v2000 if not. (pretty sure it will fit)
The X-fi is running fine on vista so no reason to replace it i think atm.
DVD/CDROM i can get later if i need to replace my older ones.
If anybody has any comments or suggestions i'd appreciate it....
AMD X2 4800+
7800 gtx 256 mb
Vista OS
630w psu
X-fi platinum
Proposed build:
Q6600 quad cpu
2x 2gb Ram
