thedapperdan
- Sep 18, 2005
Here's my configuration:
WinXP SP2
Asus A8N Sli-Deluxe (Bios 1014)
Antec True Blue 480w PSU
Maxtor 160gb drive SATA
Maxtor 80gb ATA (ide slave)
Western Digital 160gb ATA (ide master)
AMD Athlon 64 3000+
1gb (512x2) RAM
ATI Radeon X800 XL
2 IDE Optical Drives
I used to have my SATA drive run off of the Nvidia raid controller in port 1, but that gave me corruption issues. To solve this issue, I moved it to the SiL raid controller, port 1, and set it up as JBOD in the raid interface thing on boot. This solved my corruption issues, and now my system is stable.
The problem, however, is that my 160gb Maxtor SATA drive has replaced my WD 160gb ATA (ide master) drive. Both in Windows and in BIOS (1014), my WD drive doesn't show up, and is instead the SATA drive is there. Is there no way I can run 1 SATA drive off of the SIL controller, and 2 IDE drives? Or are there some newer drivers for the nvidia raid controller that would allow me to use that with a single SATA drive and not have corruption problems?
Thanks
WinXP SP2
AMD Athlon 64 3000+
1gb (512x2) RAM
ATI Radeon X800 XL
Thanks
