QFTEndurance Man said:Am i the only 1 who thinks those pieces of plastic they put on cases nowadays look SHITE. All those tooless design things, you can see them on this case in the drive bays, its looks terrible. Even worse are those ones for fastening the pci cards, reckon it would just look better with the bare metal
malicious said:3 things
1 congrats man and thanks for the pics
2 is it just me or is that cas HUGE
3 could you mount a 2x120 rad straight to back BIP or BIX II or III for that matter
pincho said:
pincho said:lol serious? i no its not popular but.. lolhow come u dnt like it? i liked it at first, and i think it gives a bit better cooling than the Aurora, but the flashy fan, dust suck-in
and not matching my Apple Cinema/mouse/keyboard made me want to get a new case.
thanks
BTW what did u do to ur's to be 'modded' ?
pincho said:heh o well looks better than my old one haha. but if u want good cooling i suggest stay with that case for a while. my temperatures on this case compared to my Icute are about 5-10 degrees celcius higher, which is sorta dissapointing, but then again it is 30c around home
make a new thread!pincho said:well this is weird, i took out the 2 side fans on the grille, cause i was getting annoyed with the wiring job, and the 80mm also.. instead, i put my Antec 2000rpm 120mm as the front intake, taking out the 1000rpm Gigabyte fan, and temperatures have dropped dramitcally![]()
also these temperatures where only slightly higher than with the other three fans on.. heh im not complainin
any ideas about the wire management solution? or should i make a new thread, so it doesnt detract from this threads point? thanks
