Freezebyte
- Sep 21, 2008
EDIT: Updated and moved to new thread
I could of sworn they had this on the egg for a long time now. Maybe my imagination.![]()
Well, at least three months if not more.
Hello xxxxx,
The SG04 will be probably available in Europe at the end of October.
Unfortunately, I do not have an exact date.
Mit freundlichen Grüssen / Best Regards / Cordialement
xxxx xxxx
SilverStone Technology GmbH
Brandstücken 43
22549 Hamburg
Germany
Tel :+49 40 675931-17
Fax :+49 40 675931-27
E-Mail /MSN: xxxx@silverstonetek.de
Website: www.silverstonetek.de
The biggest difference between SG03 and SG04/SG04-H is in the material used for the main body. SG03 is an all aluminum case (with steel lower brace) while SG04 and SG04-H have aluminum exterior (front, top, bottom, side panels) with steel interior.
I prefer the SG03 to the SG04 because front vent = better airflow than a door you have to open.
Yeah, he is. Good guy.![]()
now...if they just made this thing without a door. perfect!
I swore of doors after my Antec SX-1030
Edit They both lack a rear exhaust which in my opinion is one of its biggest design drawbacks. The other is that it being like many SFF it doesnt allow much room for larger HSF which is especially needed for quad chips nowadays.
Which also equates to more noise output, as well the side vents also allow for more noise and dust to enter as well, both of which im tired of in my SG01
Granted, I know the SG04B doesn't have the full unrestricted front panel like the SG03 does, but this shows perfectly what I find so awesome about this case. Twin 120mm fans are enough to get plenty of air flow going in and out of the case without having to deal with noise issues of using 80mm fans.
http://www.youtube.com/watch?v=VsmKHJq2aTs
annnndddd, its a win!
hi tony,
how come the SG04-H sells for around 50% than SG03?
is that a local pricing anomaly, or is the list price 50% higher, and if so, why?
cheers![]()
Pretty. When I saw you thread title, I immediately thought of this: http://www.youtube.com/watch?v=ftBgr5FSCSk&NR=1
Well, everything WAS going really well until my fucking Seagate decided to take a shit on me for no apparent reason. Now I gotta wait for my replacement drive before I can fire this thing up AND rebuild the OS. Last Seagate HDD I ever purchase...
