Yes, another reccommend me a case thread
jcll2002
Yeah, you read the title ;). Im looking for a case <$120, have a window, and I need it to have a removable mobo tray. I was set on the p160w because it has all of those things, but someone pmed me saying that the removable mobo tray isnt legit because you have to remove everything off of it to take it out while with true ones, you can take everything out. What do you suggest?
Thanks,
jcll2002
I recommend 7 pieces of 3/8" plywood and a handful of 3/4" wood screws. 6 for the box and 1 for the mobo tray.
cardboard usually works best for me.
i find that its a lil easier to cut with safety scissors.
they wont let me have sharp objects.
whaaaatttt???
plywood is real!
so is cardboard for that matter!
you can touch, it exists...
and the best part it, you can cut em to fit.
YAY!
no more lil tiny cuts from sharp edges that are too small for human hands to fit into!!!
YAY!
I would suggest getting a case without a removable mobo tray. Why do you need this? MOST cases do not have this functionality and many people buy them and love them.
Why don't you narrow down your criteria please.
What are you going to be doing with this system? Gaming?
Will you be water cooling?
If space is the need for the removable mobo tray, why not get a bigger case?
Steven
Sorry ;)
Well, Id like a solid atx case, that is stylish that will have a window because im a led whore ;). I dont plan on wc now, but it is a possibility in the future (not now because i dont know enough about it + budget doesnt warrant it).
I guess I dont need a removable mobo tray...
It will be party for gaming, but i dont want it too crazy looking if you know what i mean.
my suggestions would be
lian li pc7bplus
ahhh that's it for atx
btx is aerocool masstige
mal
whats the difference between atx and btx? I only said atx because my mobo is atx
well the atx mobo with work with the masstige .. it's just flipped over for better flow
masstige is basically a stacker with slightly smaller footprint and much smaller price tag
psu is on the bottom .. 10 5.25 bays .. plenty of water cooling placement options..
i'm drooling over the idea of putting a black ice pro 3 in the top of one ..
anyway .. check it out ..
mal
