mystical_ice
- Jun 7, 2009
You guys are probably sick of this by now, but i've been reading articles on HCP for probably 7 or 8 years now, every couple of months.
In late 2005 I built my last gaming computer. An Opteron 148, Asus A8n32-SLI motherboard, 2GB of corsair 3500LL RAM, and a nvidia 7800GTX, with two 500GB sata drives. At the time it was pretty close to top of the line, and i think it's still pretty decent to be honest. I work hard, and only have time to play games several hours each week, and the games i play are usually counterstrike source, half life 2, warcraft 3, and even starcraft sometimes. I'd always intended to overclock the 148, but who am i kidding, i'm a noob when it comes to overclocking, so i never got around to it *embarassed*
Anyway, i decided to download the Crysis demo at work, after getting a good computer, just to "test the specs" (shh, don't tell my boss). I was impressed with the game, so that night i purchased and downloaded it on my home 'gaming' computer.
I was very distressed that my 7800GTX had trouble running it, even at 800x600, and everything on 'low'. A game like that, i came to the realization, either has to be played on high settings all around, or not at all...
So that's when I decided i needed to build a computer that would be able to run Crysis well, perhaps not on 1920x resolution, but at least on 1024x768, or maybe 1280x1024. Looking for good framerates, and the ability to play other games, like, say Half Life 2, at highest settings, as well as being able to scale.
At the moment, i'd like to only run a single graphics card, just because i don't think i'd be able to run two. I'd definately like the abilty to run 2 though, as in the next few months i would be willing and able to purchase a second card.
Operating system, i've always run XP Professional, but if you think it would be worth installing and running Vista Ultimate 64bit, i'm open to the possibility if the performance would justify it.
Anyway, here's what i've come up with for now - tell me what you think. I've heard it's good to match RAM frequency to FSB frequency, or something like that. Is that true?
Here's what i came up with:
- XFX Radeon 4890 XXX Edition with 1GB DDR5. ($219)
- Asus P6T Deluxe V2 motherboard ($309)
- Intel Core i7 920 2.66Ghz ($269)
- Corsair TX750W 750W power supply ($114)
- Corsair XMS3 Tri Channel 6GB PC10666 DDR3 3x2GB ($109)
- Hard drive i'm not sure of. i'd love to get one of those SSDs, but i don't think i can afford it. whatever ya'll suggest for a nice, very fast hard drive, that doesn't cost $250.00, i'm fine with.
I'd like to overclock a little, as long as it's going to run stable. My gaming computer at home sits off, and i turn it on only when i'm ready to play a couple of games.
Any suggestions overall, i'm happy to listen to. If you think i can get similar or exact performance from cheaper hardware (perhaps the motherboard?) then i'm all ears! Really don't want to spend more than i have in the above list if at all possible. maybe $100 or so. I already have a case, fans, etc.
Thanks for your help in advance.
To answer the questions required:
100% gaming
see description
3) Where do you live?
Houston, TX USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
see description
only the case and fans
6) Will you be overclocking?
if i can do it safely, then yes
an Acer 22" widescreen
within a week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
N/A
10) Do you already have a legit and reusable/transferable OS key/license?
yes
100% gaming
see description
Houston, TX USA
see description
within a week
N/A
yes
