Yay new comp, question
kc7hif
Put it together and booted fine and all is well. My question is, do I need to adjust anything in the BIOS with respect to clock speeds etc? Right now it's using a multiplier of 20x133=2.66 ghz.
i7 920, GA-X58A-UD3R, Corsair XMS DDR3
So I would need to set the voltage for one, and adjust the multiplier and bclk to:
multi: 14 , bclk: 200 instead of 133? Assuming ram multiplier is x8 it's currently running at 1066 mhz?
all you have to set is the ram divider 2:8 or 2:10, set the 1.65v for the ram.
2:8 is 1066-> 2:10 would be 1333 -> 2:12(if it exists) would be 1600?
