Z
Zinn
Guest
I love new tools! There's nothing quite like ripping open the box to awesome new power tool and sniffing all the wonderful new plastic smell. It's Christmas all over again! I feel giddy like a schoolgirl! Yay!
Er, anyway. I've gotta say I'm impressed by the construction quality of the Dremel Multipro 2855-01. It feels very solid and there is a lot of attention to detail. I've never used a rotary tool before, so maybe they're all super awesome like this, but yeah, it's definitely a great piece of engineering. I can't wait to fire it up!
A couple of questions:
1) Will the non-reinforced cutting discs that came with the kit be sufficient to put an 80mm fan hole in aluminum? Or should I get some better discs?
2) Should I use this thing to cut plexi? I've heard that plexi can melt at the higher speeds, so is lower speed okay to cut it with, or should I look into another method of putting a hole in my side window? (Not even sure I need to do this yet, we'll see how the extra 80mm hole does)
3) Can you guys give me some tips on what I can do to improve airflow in this thing? At stock volts and 3.15 ghz my E6300 w/ Zalman 9700 is loading at 60C (I've mounted and remounted and remounted). Running with the side panel off drops both ambient and load temperatures by 10c. I think the wind from the chipset fan is interfering with the 9700 to some degree, but that one low-CFM 80mm fan in the back isn't helping.
I'm dead set on another 80mm fan in the back, (not sure why Lian Li didn't at least cut this in the first place). Wind from the 2 80mm fans in the front bottom is effectively blocked by the 8800 card, so there's a pretty sizeable deadzone in the front.
I was thinking about putting one of these bay-intake HDD coolers in to bring more air through the front and pointed at the CPU area. Or would that extra 80mm hole be sufficient? Or am I way off base?
A pic of my crappy airflow setup:
Help me out here! I'm pretty new at this airflow stuff. Thanks
