Drudenhaus
- Sep 27, 2005
Over the course of the past year or so, I've bought half dozen or so Yate Loon fans (D12SL I believe). It seems as though every few months, I'll get this horrible humming noise coming from my case. Each time, a quick diagnosis reveals that this hum is coming from one of my Yate Loon fans I'm not sure of the exact cause, but putting a slight amount of pressure on the middle/motor section of the fan silences the hum (it is VERY audible from anywhere in my room otherwise), so maybe it's the motor going? So far I've had to replace an intake fan and both fans on my radiator (actually the 2nd one on my rad is silenced by a strategicly placed 12V battery which silences the hum until I order another Scythe S-Flex fan).
I also have Scythe and Panaflo fans in my case, both which have been running for just as long as the Yate Loons (if not longer), but neither have exhibited any problems thus far.
Have any of you experienced any similar issues with Yate Loons having a short life span? I know they're fairly cheap...so maybe this is a situation of "You get what you pay for" with regards to lifespan.
