Yate loon d12sh-12
afunguy25
My yate loon's d12sh-12 120mm case fans are RPM: 2200 +/- 10% @100% but performing about 1550-1600rpm @100%(speedfan, AbitEq, mobo monitor) Anyone know how I can make them operate at 2200RPM's
My other Cpu fan ran fine(Intel stock fan heatsink) at 2500RPM weird
you sure they are d12sh-12 ? did u check the sticker? from the speed they look like D12SM-12
I just did a google search with the part number you posted up
FrozenCPU Jab-tech petrastechshop all carry that model number and a few other sites have them to
I picked up 2 yate loon 140mm's from yesbuy took them 7 days to process my order to ship it out via snail mail
other then that they work great
Do you have them hooked up on a fan controller
you might want to check the amps the controller puts out if your using one
Download speedfan and adjust your fan speed
I would run them direct to the psu
Theres a chance you might smoke the connections on your board pulling that many amps from the board
