I'm thinking about buying a 2.5" drive at BB zdata 500gb 2.5" external usb drive, which comes with Y-USB cable. Since PC's USB port spec says the max it can provide is 500mA it can provide, there is a good chance I might need to use Y-USB cable. Problem is I only have 1 free USB 2.0 port to play with on the PC I want to buy this for... From a feedback by one user looks like zdata uses samsung 2.5" drives, which more likely to some specs I found it uses 850mA @5VDC, hence I believe it will need a Y-USB cable.
My qestions are:
1) Would I be able to use an external USB power adapter (power brick) along with USB 2.0port on my PC with the Y-USB cable? Would that be safe? I don't want to take any chances to blow-up my PC
2) If the drive will seem to be working with using a single USB cable (without need for Y-USB cable) is there a chance the data might get corrupted on the drive if there is not enough "juice" being provide to it? or will HDD either work or not work at all if there is not enough juice being provided?
TIA
My qestions are:
TIA
