grandpatzer
- Feb 24, 2010
For my second watercooling PC I want to not have a reservoir.
I know the common thing is use T-fitting but aquatuning does not have T connector for my 11.1mm ID tubing, they actually have PVC 10mm that should work with hose clamps or zip ties but I'm worried risk of leaks.
I did find metal Brass Nickel Y-fitting 13mm so once warming the tube it will fit nice and with zip tie will be really well sealed.
Question: Is there any reason to not use a Y fitting 13mm Brass isntead of a T-fitting which I don't find?
The 10mm PVC T: http://www.aquatuning.de/product_in...---T-tubing-connector-UV-red--High-Flow-.html
The 13mm Brass Y: http://www.aquatuning.de/product_in...-connector---Brass---black-nickel-plated.html
