[BB] Rick James
[H]ard Dawg
- Apr 4, 2004
My guess is that this is a heat issue but I'll describe it and let you guys give me your diagnosis.
I bought an X800 XT about 3 months or so ago. It was working great all the way up to the 5.1 drivers. The 5.1's came out I did a clean install of windows and installed the 5.1's. (All other drivers are current; in all my clean window installs) After installing the 5.1's I started getting VPU recovery errors. This would happen very sporadically; really no rhyme or reason when they'd happen. They could/would happen after 5 mins of game play or after about 2 hours of game play. So I thought it was just the 5.1's. So I did another clean install and I installed the 4.12's; which previously I had no issues at all with. Well the same thing started happening with the 4.12's on my clean install as well. So I do another clean install, reformat and install the 5.1's again just thinking that it's something with Steam's most recent patch or something.
Well recently the issue has started happening a lot more; at least 3 or 4 times in about 1.5 hours. My system is in my sig and I've got the SN95G5 which does make my cards run a little hotter but nothing to the point where over heating I would be an issue; I wouldn't think. My side panels on the case have the mesh sides so breathing shouldn't be an issue.
What do you guys think? Video card issue? Granted this issue just started happening one day out of the blue. The cards fan runs as it should. As I'm sitting here typing the temp on the card is only 43C; I dont know the load temp. 
What do you guys think? Heat or Valve update messing something up? I don't play another other games right now; just CS:S.
