XSPC X20 150 Enough?
Watcher
Hello there, I'm planning a small water cooling loop for an HD 5870 only that I'm planning to get with a single thick (47mm) EK 120mm radiator and I was wondering. Will an XSPC X20 150 pump/reservoir be strong enough for the loop? Just cooling the GPU, the CPU is on separate loop.
Thanks
P.S.
If I decided to get an HD 5970 instead, would that setup be enough to decently cool (40C-55C on load) the card? Still new to water cooling and still learning, excuse my newbness :p
