magda
- Sep 26, 2018
I got a couple of 1/4" ball valve from XSPC and Im having some leaking problem
The fitting is torqued with a wrench not by hand and it is as far as it goes. but as you can see, the oring doesnt look like it is tight enough.
I didnt have problems with these fittings before...
Has any of you have some insight about using these valves?
