XSLT/XML question
I am trying to write the following using xslt.
<a href= "pics/colosseum.jpg"> Roman Colosseum </a>
I am having problems with the tag. The “Roman Colosseum” gets replaced with <xsl:value-of select="name"/> which works fine but when I try to make it a link I am missing something with the syntax. The following is the complete statement but does not work.
<a href= <xsl:value-of select="name"/>><xsl:value-of select="name"/></a>
Thank you for your time,
If you need further clarification let me know, I tried to be as clear as I could be but sometimes when you are working inside something you don’t see the whole picture.
Any suggestions on how to get this to work would be welcome.
