XPS GEN2 Bluetooth
KingPing
Hi all,
A couple of moths ago I purchased a Dell XPS Gen Laptop. I opted with the Intel 2915 wireless card and chose "no" to Bluetooth. Well you may find this surprizing but now Im looking to use the Bluetooth with my new Razr cell phone. My question is if I buy this..http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5244009512&category=31534 can I install it??..and is it difficult to install??
these are probably silly questions but I am still pretty "noob" to the laptop world.
Thanks in advance
King
Works with the following Dell laptops:
Inspiron XPS Gen 2
Inspiron 9300
Inspiron 6000
Latitude D810
Latitude D610
Latitude D410
Latitude X1
Precision M70
Precision M20
Supports the following laptops that have the 10-pin connector installed:
Inspiron XPS Gen 1
Inspiron 9100
Inspiron 8500
Inspiron 8600
Inspiron 300m
Insprion 600m
Latitude X300
Latitude D500
Latitude D800
Latitude D505
Precision M60
I think it should work.
yea I saw that too but ebay can be "sketchy" on occasion;)
then again for $35.00 its not a huge risk anyways...thanks for the input:)
It will work. I forgot to add it to my XPS order and ordered it separately from E-Bay. It is real easy to install. Just take off the small cover next to the battery, connect the cable, tuck it back inside, secure the cover and away you go.
