A friend of mine wants a new rig and I offered to put it together for him but first I would like some confirmation on these parts which will be used:
(edit: Please see bottom of this post)
I'm hoping to get a 2.5GHz overclock on this although my friend would probably be happy with 2.3GHz which I think this should get comfortably? Does the NF7-S run ok with XP2600-M's? The DFI Lan Party costs a bit too much. Also would you recommend PC2700 / PC3200 memory? Seeing as the CPU is only FSB266 I thought PC3200 memory wouldn't be needed but I'm not sure just how well these Mobiles overclock and I'm sure I've read a lot of them reach FSB333 or perhaps even FSB400, would this be an accurate assumption?
Also is it worth paying £20 more for an XP2600-M instead of an XP2400-M?
All feedback is welcome, thanks
=============EDIT=============
Newest Spec:
Newest Spec:
AMD Athlon XP2400-M Mobile £55.81
GeIL 512MB (2x256MB) PC3200 Golden Dragon CAS2 £77.89
DFI NFII Ultra Infinity (Socket A) £61.10
PowerColor Radeon 9800 Pro 128MB £151.58
Thermalright ALX800 (Socket A) Heatsink £22.33
YS-TECH FD8125 80mm Fan (3 Pin) £5.17
Arctic Silver 5 Thermal Compound £6.76
Casecom KG-3966 Silver 300watt ATX Case £19.97
Super Flower Real 420w Dual Fan Psu £35.24
Western Digital Caviar 120Gb 7200rpm £58.74
Toshiba 4x DVD-R/RW £49.78
LiteOn LTR-52327S £20.79
Alps Floppy Disk Drive 1.44MB £4.53
56k v.90 Modem £8.17
Arctic Cooling VGA Silencer £5.84
8cm Internal Case Cooling Fan 4 pin £0.57
Ebuyer AC Power Lead (Kettle Type) £1.17
