lithium726
- Jun 16, 2004
im trying to decode between these two coolers - my zalman just isnt doing hte job anymore since i got the X2, runs too damn hot. since i havent looked at coolers in a long time, im kinda lost, and ive gathered that these two are the best you can get. which one would you jump for? what kind of fan would you put on it?
currently, all the fans in my computer are <21db, and id like to keep it that way. im leaning towards the 120, should i lean the other way? is the SI-120 any better than teh XP? i know the XP will fit my board, so thats not an issue.
is the 90c too heavy for its own good? is it going to rip my board apart?
system specs in sig
system specs in sig
