Morning all.
Ive got 2 160gb HD's in my comp. One is for storage, the other is currently split into 2 80gb partitions.
I installed XP Home on the first partition without a hitch and it has been working perfectly for weeks.
Now heres the problem, i installed Vista64 on the second partition and now i cannot boot into XP any more?
As soon as i installed Vista i installed EASYBCD and was expecting to see 2 entries, one for Vista and one for XP. There was only Vistas there so i created an entry myself for XP.....it didnt work.
Someone suggested i 'fixboot' the XP partition which i tried but nothing changed. When i first turn the comp on it has 2 entries, Vista and the XP one i created in EBCD if i select XP it just resets?
Any ideas would be welcome.
Cheers in advance.
Cheers in advance.
