Taffy Apple
- Sep 4, 2005
I have a XP Pro box, and applications and explorer keeps falling over. And when explorer isnt falling over the box is BSODing. I usually get a 0xc0000005, but occasionally get a 0xc0000021a. The thing is Ive read so much about similar problems that Ive got information overload and dont know what to do next!
I ran memtest86, and it came back with a few fails in test 5. But Microsofts memory test thing said everything was fine (typical). Now if I was just getting the c5 stop message then Id go get a new ram stick, but the 21a stop is confusing matters and I dont want to waste my money on a ram stick that I dont need.
I have an ancient 98 box that I know works, and ive been thinking of just swapping the disks to see if the error migrates onto the 98 box. Now I cant see that swapping the disks would be a problem, but has any1 tried a swap like this and had complications?
Additionally can any1 suggest my next step, apart from getting some sleep!
