XP SP3 Install after system failure
Ajax9000
Its been quite a while since I've had to do any hardware debugging like this so I'm a bit rusty and feel that I'm missing something obvious; can anyone help please.
Recently our general home PC has been a bit sluggish so I decided to do an offline supervised virus scan. Turns out the automatic updates hadn't been coming in for a while, but I decided to run the scan first, before going back online to get any updates. The Netsky worm was lurking on the system along with the usual rash of tracking cookies. Cleaned that lot out, turned on the cable modem, and went looking for security updates.
That’s when things went weird. Started getting those dialog boxes "Your system may be vulnerable to attack. To protect your system download the latest security suite from XYZ" ... yeah right, killed those PDQ. Shortly after that the wallpaper dies and on CTL+ALT+DEL get a message "Task Manager has been disable by your Administrator". So it looks like I've caught a more malevolent virus. Bugger.
Shutdown, disconnect main drive (IDE) and jumper it to Slave. I've been building a new SFF for my daughter and I've been meaning to update to XP SP3 and get a bigger HDD anyway, so I decide to get a new HDD and a new XP licence, do a clean build with the latest anti-virus, etc. THEN recover what I can from the old HDD.
The system is as follows:
Gigabyte GA-8S648FX in a generic tower case
512 MB DDR 400 (CL3) >> Upgraded to 2.5GB DDR 400
Maxtor 60GB (Master on IDE1) >> disconnected for the moment >> Replaced with a new Hitachi DeskStar P7K500 250GB (Master on IDE1 - NB changed jumpers to Master from factory setting of Cable Select)
Seagate 10GB (Slave on IDE1) >> disconnected for the moment
Liteon CD/DVD combo (Master on IDE2)
Gigabyte GV-R9200 AGP (no onboard video, so I can't remove this)
Windows XP SP3 OEM CD
Boot from the XP CD -- ok
Partition & hard format 50GB C: -- ok
Start install -- gets 75% through and BSODs Stop Code 0x00000024, problem with Ntfs.sys.
Restart (CD boot), soft format C: try again -- same result
Restart (CD boot), go to recover & run chkdsk -- no errors found
Be anal and hard format D: then restart (CD boot) install with another soft format of C: -- same BSOD
Take out original Windows XP SP1a OEM CD and try installing that -- completes first stage install, restarts correctly with XP splash screen, goes to second stage install, gets past Product Activation, Set Time, etc, then BSODs (may have been a different Stop Code, I can't remember)
Give up for the time being …
This is no-longer looking like a virus problem.
Googling Stop Code 0x00000024 leads to a bunch of places (e.g. Error message in Windows 2000: "Stop 0x24" or "NTFS_FILE_SYSTEM", Windows XP Stop Messages, Troubleshooting Windows Stop Messages) that say things like:
1 > tools that continually monitor a system such as virus scanners, firewall software, backup programs, disk defragmenters can cause problems, so try disabling them. Heavy hard drive fragmentation or heavy file I/O can also cause problems.
2 > Malfunctioning SCSI and ATA drivers can cause read/write to disk errors.
3 > Malfunctioning SCSI and ATA hardware can also cause read/write to disk errors.
4 > BIOS upgrades can sometimes resolve the problem.
Well, #1 would seem to be out as it is a brand new, hard formatted HDD with the only software involved being XP; #2 would seem to be out too as I can't even get to the driver installation phase of the install.
So, what are my options for debugging any hardware or BIOS problems?
I was going to try:
>> Changing the IDE cables with some spares I have.
>> Swapping the CD and HDD so that the CD is Master on IDE1 and the HDD is Master on IDE2 -- but the manual for the GA-8S648FX explicitly states that the primary HDD needs to go on IDE1 and the CD on IDE2
>> Abandon the tower for the moment and see if I can use the new HDD to finish off the SFF build -- which will at least verify that the new HDD is OK, but doesn't actually address the problem.
>> Get a $20 PCI PATA card to bypass the onboard controller if it is failing -- assuming I can even set the system to use a boot disk hanging off the PCI bus (I can't see any option for this in the BIOS manual).
>> I don't really want to flash the BIOS.
As I said, I feel that I'm missing something obvious. What should I try first? And are there any other things I should look at?
Thanks!!
LoStMaTt
Umm have any other hard drives around? If not then finish building the SFF and transfer your stuff to that machine temporarily while your format the old drive and try to load XP. If its successful than that new drive you have is just fubared.
Ajax9000
At the moment, unfortunately, no; I only have the three drives mentioned. I need to get a stable system built so that I can scan and recover both the old drives' files (and the SFF has't got the connections to do this easily). The intention was to wipe the Maxtor and move it to the SFF -- as the tower has all the higher spec components there isn't much point in putting the Hitachi in the SFF.
Because I don't have any spare drives, making the SFF the (temporary) main PC is my least preferred option, simply because of the faffing around involved:
> build the SFF with the Hitachi (assuming it isn't fubar)
> virus scan and migrate the old drives' files
> wipe the old drives
> rebuild the SFF with the Maxtor
> copy everything back onto the Maxtor from the Hitachi (for safety if nothing else :)
> try again with the tower ...
Looks like I won't be doing much else this weekend. :-/
Ajax9000
Well, the new Hitachi drive is fine. Installed XP SP3 using it in the SFF OK. The system is sluggish but I think that is due to running 1920x1200 with Intel GMA. (Not a priority to fix yet :)
So it is looking more and more like there is a problem with the IDE cables or the motherboard.
