ObscureTerror
- Aug 29, 2007
I just installed SP3 on my wife's laptop, and have gotten a few strange errors. Though nothing since (only bee a few hours) I don't know if there's something wrong or not.
First error: a pop-up box (like a CMD) box, two of them, listed the error: "Error in parameter", then they both closed.
Second error: upon opening Diskeeper to defrag, keep getting the error: "Detected error in the MMC snap-in" (Microsoft Management Console; had to look up what it even was), though the program will run.
Third error: upon opening Firefox, ESET Security detected a change in the "svchost.exe", and I allowed it, since I figured it was a change that SP3 had made to my system. I don't know for sure, however. Haven't gotten since I allowed.
Upon checking the Even Viewer, I found the following "issues" listed, but again, have no idea what (if any) problems these represent:
I have Computer Browser disabled in Services, and there was an "error" about that starting in Events, but I don't know if that's causing a problem or not.
Any info/help appreciated.
The description for Event ID ( 1000 ) in Source ( Microsoft Management Console ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: dfrgsnap.dll, 10.0.593.0, dfrgsnap.dll, 10.0.593.0, 00007270.
A provider, Rsop Planning Mode Provider, has been registered in the WMI namespace, root\RSOP, but did not specify the HostingModel property. This provider will be run using the LocalSystem account. This account is privileged and the provider may cause a security violation if it does not correctly impersonate user requests. Ensure that provider has been reviewed for security behavior and update the HostingModel property of the provider registration to an account with the least privileges possible for the required functionality.
A provider, HiPerfCooker_v1, has been registered in the WMI namespace, Root\WMI, to use the LocalSystem account. This account is privileged and the provider may cause a security violation if it does not correctly impersonate user requests.
