Jan 31, 2006 #1 L l0cke Gawd Joined Aug 13, 2005 Messages 810 Yeah, I was changing some view settings, trying to get the filmstrip on one of my folders and this happened. I ncase you can't tell the blue sidebar is gone. On all my folders too. Also my folder options are messed up. help?
Jan 31, 2006 #2 C ChingChang Supreme [H]ardness Joined Mar 27, 2003 Messages 6,504 In any folder, go to Tools at the top, then Folder Options Then just click the button at the top to show common tasks in folder or whatever it's called. You can also go to the View tab to change other settings that got messed up. You might have to click the button to apply the changes to every folder. edit: nm, the 2nd pic didn't load so I didn't know...
Jan 31, 2006 #3 L l0cke Gawd Joined Aug 13, 2005 Messages 810 Also, I recently customized my start button so that might be it....
Jan 31, 2006 #4 L l0cke Gawd Joined Aug 13, 2005 Messages 810 does anyone know if the explorer.ex file in the winodws disk is the same as explorer.exe in winodws?
