XP Professional student
rm.o
I bought XP Pro student upgrade, and it came with product keys and cd for both the x86 and the 64-bit version. Is it ok to install both, on seperate computers that I own? The reason I ask is my new laptop came with XP home and I'd like to upgrade it to XP 64, and I have an old 98se computer due for an upgrade.
There should be a license agreement written on documentation that came with the OS. It will have the answer you seek.
Assuming you have separate keys for the two versions of XP, then it *should* be okay. I would still verify in the agreement.
All I have is the two CD's with different keys. Are you talking about the EULA you accept right before you install?
