XP Pro stuck in endless rebooting loops
kethnaab
I am trying to install XP Pro from the CD onto a Windows Celeron 633 with 192 MB
of RAM and a 30GB HDD.
The computer recognizes the CD and HDD, asks if I want to install any 3rd party drivers
and the like (F6 button)
It keeps on going, formats using NTFS, starts copying files for installation, then
gets to a point that says 'This portion of setup has completed successfully, remove
any disks from the A:\ drive, computer will reboot in 15 seconds.'
so it reboots, and it goes through the cycle again.
It reads the CD, asks if I want to setup Windows XP, then says "hey, there
is already a \windows directory on the C:\ drive, do you want to do a dual
boot, do you want to delete the contents of this folder and install windows there,
or do you want to install to a separate directory", then it gives
some gibberish about checking the microsoft website for advice on dual booting.
It does this over and over and over again. I tried disabling ACPI in my
BIOS, and hitting F5 while setup was starting, but the F5 didn't seem to do
anything at all. I tried ejecting the XP CD ROM and restarting, but then it
starts up and says "Missng Operating System"
why the heck does XP insist on restarting, only to go through the exact same setup
steps again? And why can't I disable ACPI?
bah. thanks for any help.
this is driving me nuts.
hurm
"couldn't open boot partition to check for a signature"
I caught this message before it rebooted, once again, into setup
any thoughts on this? PLEASE!?!?!
I've even tried this with Win2k, and it's doing the same damn thing.
Hm, well Im not positive, but Im pretty sure (I just reinstalled windows on a friends machine) that once you reboot you do NOT run from the cd and let it start up like it was starting up windows then it will start using the cd again to setup windows. If im way off here let me know
You don't let the CD boot again after files have been copied. Just don't press anything when you are asked so and it will be fine. When you get the Missing OS message, that might mean 2 things: You either didn't set the boot device to your HDD, or which is mostly to be, your MBR is corrupted and that's why you get this message even when there is one OS on your drive. Try reformating the partition or even fdisk /mbr from a 98/Me startup diskette. If it doesn't help - take the drive out and format on another PC. Is it 815 based mobo? Cuz i had some serious trouble with one of those from QDI and it's IDE controller. Now i'm writing from it in a matter of fact.
""couldn't open boot partition to check for a signature"
I get this message if I keep hitting "N" when it tries to boot up.
i.e. I say "no" to "Boot from CD-ROM"
I have made adjustments to boot from HDD or from CD-ROM, doesn't matter.
I think I'm having MBR problems, as you mentioned.
Yea pull the CD out. That would be my first guess.
I took the CD out. I tried that. I tried booting without a CD. I tried changing the boot order. I typed "n" when it asked "do you want to boot from CD-ROM", etc.
The computer will NOT recognize any type of operating system if I do that after the first part of setup commences.
thanks again though.
