XP Pro Install - Partition Problem
hmorphone
I just built a new C2D rig. In preperation for the build I used my old rig to format the new hard drive with NTFS and create two large partitions. I'm considering picking up Vista later on and going dual boot with each OS on it's own partition.
When I built the rig (and installed XP Pro) I ran into a temporary glitch booting with the Badaxe2. I ended up allowing XP Pro to do a quick NTFS format of partition 1, the one I installed XP Pro on.
Here's the problem. Later I noticed that boot.ini, ntdetect.com, and ntldr were all installed on partition 2 (instead of partition 1 where the rest of the XP Pro install went.) I assume that just moving these to partition 1 won't work, and I've put too much work into the XP Pro install just to reformat and reinstall it.
Is there anyway to move the boot files to partition 1 without messing anything up ?
I suppose you could try merging the two partitions using a partitioning utility like GParted... I don't know if that would work, but I think it would..
