XP Pro 64bit not booting with Nvidia Quadro Drivers
snizoley
System:
2 dual AMD Opteron 265
Tyan mobo
4GB RAM
nVidia Quadro FX 1500
74gb Raptor 10krpm
600watt PS
Windows XP Pro 64bit SP1
How it started: I was running two monitors cloned on my quadro, and playing BF2 with the new XP Pro 64bit drivers for my card. Everything worked fine for 1.5 days until I crashed in game with video artifacts on my screen.
I restart my system, and during the Windows loading screen, it displays a blue screen of death for 1/2 a second and reboots on its own. I went into safe mode fine, and reverted the system back to a previous date. Same problem. I then read that some monitors dont have support for 64bit, but have been running 2 of them for 1.5 days just fine on the machine. I have tested seperatly four different CRTs and the problem persists
I then uninstalled the video drivers in safe mode and the system boots up perfectly. When I reinstall the drivers and restart the machine, the system crashes on boot like before.
Can anyone please help me out with a solution?
Thanks in advance
-snizoley
Try a different driver version, if there is one.
Personally, I don't care for the 64-bit XP. I used it for a few months and had endless little quirky problems that immediately disappeared when I went back to the 32-bit version. For example, my network card would not connect to any internet servers (web, email, irc, im) for at least 60 seconds after the system completed booting to the desktop. It got its IP from my router, but would just not connect, at all.
After dealing with crap like that for a while, I got tired of it and reinstalled ye olde 32 bit standby, and the problems disappeared.
I am at my computer technician and hes taking a look at it.
I have 4gb of ram I would love for 64bit to work so i can take full advantage of it.
Thats the first thing Im going to try, load up older version of the nvidia display drivers.
