ah thanks.On a new build you're not likely to run in to serious issues with Vista. Most of the problems people have are due to old hardware.
fagShit flip a coin it really doesn't matter becuase if you don't already know the answer already then it isn't important enough for you to notice much of a difference between the two.
Some of you said gaming = vista, but don't games run much faster on XP?
I will be doing lots of gaming and also school stuff. I have heard a lot of good and bad about vista so I'm kinda hesitant to pull the trigger. Especially when XP is just fine.
Sounds like you've already got your mind made up, and as such, XP x64 would be the recommended OS. If you want Vista, then Vista Home Premium x64 as others have said. But if you're still fond of XP, and you want that OS, then XP x64 is the way to go on a new build (new meaning multicore processor with a lot of RAM).
I'd say if you were going to go 64-bit you might as well bite the bullet and go Vista - better driver support than XP in the 64-bit flavor. If you stay XP, stay 32-bit.
As long as you're using quality hardware components and not the cheap shit at the register of every computer store on the planet, you'll be fine, and you'll get 64 bit driver support for pretty much every piece of hardware made today and in the past 2 years. I can't absolutely guarantee that, of course, but in the years that I've been using XP x64 (and many other people as well), there has never been a piece of name-brand hardware I've used, installed, or owned that I could not find a proper 64 bit driver for. Not one.
