XP on a vista system?
sharkdiver420
Hey all,I just got a new laptop and it comes with vista premium. I was wondering If I could format it and put XP pro on it instead without any problems..here are the specs..
Intel® Core™ 2 Duo T8300 (2.4GHz/800Mhz FSB/3MB cache)
Genuine Windows Vista® Home Premium Edition
High Resolution, glossy widescreen 17.0 inch display (1920 x 1200)
256MB NVIDIA® GeForce® 8600M GT
3GB Shared Dual Channel DDR2 at 667MHz
Size: 250GB SATA Hard Drive (5400RPM)
CD / DVD writer (DVD+/-RW Drive)
Intel Next-Gen Wireless-N Mini-Card
Built-in Bluetooth capability (2.0 EDR)
No Webcam Option
56Whr Lithium Ion Battery (6 cell)
Integrated Sound Blaster® Audigy™HD Software Edition
My Software & Accessories
Trend Micro Internet Security 15-months
Microsoft Works 8. DOES NOT INCLUDE MS WORD
My Service
1Yr In-Home Service, Parts + Labor,24x7 Phone Support
Included 3 GB DataSafe Online Backup for 1Yr
No ISP requested
Also Includes
Integrated 10/100 Network Card and Modem
Adobe® Acrobat® Reader 8.1
Windows Vista™ Premium
Intel® Core™2 Duo Label
Premium Deep Metallic Pink w/ Soft Touch LCD back color w/o Camera
Inspiron 1720
No Entertainment software pre-installedCompatibility Alert
Recalculating Price
Depends on if drivers are available; check the manufacturer's site. Since it's a Dell, you should be fine. YMMV.
Yeah, you should be fine if you just pop in the XP disc and install.
Exactly. In the time it took for the OP to type that post, he could have gone to Dell's support site, popped in the service code, and found out for sure if XP was supported or not. My new Latitude D630 came with Vista Basic (cheapest option), but I formatted it and went to XP Pro, from our standard VLK and image. No problems, but I did check to make sure the XP drivers were available.
Almost all of the mainstream system builders are still building out drivers for both OS's you should be good
Bought a laptop from compusa out of buisness sale. had vista. tore it out and installed XP-64.
Runs awesome
HP Pavilion dv2620.
Last time I made a vista system XP nothing would work..even with me finding the generic
drivers. This was on Sony Viao that the only drivers were for Vista.
It was a major PITA
What did I miss? Where does it say it's a Dell? If it is, should be easy to run XP. I am keeping it on my laptop. I still recommend XP over Vista on a laptop. Better drivers in most cases.
Why do you want to emulate a good OS inside a crap OS? Obviously the OP wants to use XP because he recognizes it's a better OS.
Wow, it just never ends! Maybe he wants to chose a good OS out of two good OS choices? Running XP in a VM is a perfectly valid option. If the OP wants XP, it is a very simple process to check if XP drivers are available. Do we really need to play the ridiculous boo hoo Vista is crap game any longer?
Maybe I didnt think about checking the site to see if they had drivers for XP.Your first sentence here makes me think you are a smart ass.You have only been here 6 months,Dont be like that.
Thanks for the help from the rest of you guys.Im going to format it and see how it goes.
You can certainly try. A lot of OEMs are not spending the money to develop driver for XP on their newest Vista computers.
On the dell site there dont look to be all the drivers for the video card a few other things but Im thinking I can go to the nvidia site and get them.Im going to wait till my laptop gets here before I make a final decision.I want to check out the model #s of the bluetooth and some other things it has first.
