ta addict#2
- Dec 8, 2005
I want to install xp on a pIII system with a 440 chipset but can't find a chipset up-date inf for xp and this chipset at intels site,what to do
XP runs very smooth on a P2-400 with 256MB of RAM, as I did it for 1.5 years or so (before upgrading). Make no mistake, it's not going to be FAST, but you shouldn't have too much problem. As already mentioned, that should be enough RAM but if you can throw more at it, you'd be better off.ta addict#2 said:ok I found a different download page by using a google seach at intels site that list xp as a supported os for the version 3.29 I think it is up-date inf for the 440 chipset so I'm gonna find out if xp can be configured to run fairly smooth on a 400mz pIII with 325mg of memory,hope it will make a good e-mail web surf rig
thanks
I believe that had to do with ACPI...it was a bios setting I believe. I had two Asus P2B's and 2 P3B-F boards...all 440BX chipsets and had no problems on shutdown.ThreeDee said:you might have a problem with the computer shutting down correctly , where it might just say "It is Safe to Turn off your computer" message instead of actually shutting down.
you can google around for solutions to fix once install is complete and you dont want to do a repair re-install ..otherwise you can hit F5 when booting off of xp cd and you get the initial message to hit F6 to install 3rd party drivers ... and try selecting standard pc (I forget exact option wording) .. sometimes you have to expirament with different options until one works (if having your computer being able to shut down on its own is something you want)
