MrValentine
- Jul 5, 2004
OK first look at this MS kb.
http://support.microsoft.com/kb/822904
Look at step 4 of the Workaround. Try it on a XP SP3 fully patched box.
I cant even list the files at command line with DIR. (File not found)
The only way I can delete the file is to do so using explorer, and it does fix the orginal issue just like the kb says it should.
Anyone got any ideas? I have a few hundred machines to run this on, and doing it manually in the gui is not an option.
