XP Key Switch
blare
Aight guys I kinda put myself in a tough spot. I have two machines one is a custom build and the other is an OEM dell system. I reformatted both then accidently(really stupid) activated the OEM system with my purcashed license of XP. So now I am stuck with an OEM code. Is there any way I can I pull a quick switch off. Its kind of important that these systems get up fast.
So should I use the Purchased code on my build and that will invalidate the other machine? Then will I just be able to insert the Oem code into the oem machine?
Thanks, blare
RockXP rarely works for me. Magic Jellybean should work, and Microsoft has their own tool called KeyUpdateTool for just this task.
