gah
Ok what happened was:
I was downloading the new windows vista public beta, it was like 20% done, and i decided that i better make a new partition for it to install on.
So i used partition magic to resize d: (which xp is installed on) back to 100gb, and resized c: ( which was empty) to the rest. Restarted and it was all good.
Decided to format c: because currently it was in fat32, while i wanted it in nfts. So i used partition magic to convert it to nfts. Restarted once again, and windows wouldnt boot, said nftl or something was not found, and just sat there. I decided to install xp on the c: to see if i could recover anything, and thats what im typing on now.
I have been able to just straight copy most of my files over to c:, but some things, such as documents and settings, which i had protected so no one but me could access, cant be copied as they *of course* deny access.
So my question to you, Hardocp, is there any way to either boot into my d: drives xp installation, or even to copy my documents and settings over to c:?
awaiting your reply
awaiting your reply
