Hey, i recently had to re-format my hard-drive (i was switching to linux and now i wanted to go back). so i removed all the partitions and put in my XP pro CD, upon installing it says that a lot of files are missing on the CD, i then tried another CD with the same problem. do you think this is a CD drive issue? or is it really bad luck and i should search the web for another copy?
