I tried doing a search to fiind out if anyone else has had similar problems, but no luck there.
Here is the problem, when i first start up the computer everything boots up fine, runes through the BIOS and then it goes to start windows and nothing happens, just a blank screen, hard drives not truning nothing.
I hit the reset button, it boots up again, but this time it dumps me into a windows touble shooting screen. Where I have the option to normally start windows, plus the start with last know good config, plus the myriad of safe modes, if I let the time run down it will just go to a blank screen, if I hit start windows normally it loads windows, with out a problem and runs just fine. Never seen anything like it.
I have been trying to figure out what I did exactly to cause this, a few days go the I fired up and the mouse and keyboard would not work, I rebooted and all was fine, then this started happening. I am not even sure how to trouble shoot this.
Anyone out there have this happen to them before? or have any ideas of what might cause it? I did do a windows update in teh middle of last week, but it worked fine after that. Is there a list somewher ein XP of the updates syouhave done? I just looked the the add/remove programs and there is nothing there. The last one had to do with Microsoft Frame something or other.
This is frutrating and worry some and the same time. Any help is much appreciated
Thanks in Advance
Thanks in Advance
