Had this issue earlier
XP home is on the server
XP pro is on the terminals (restaurant registers)
1; Can see, map, RDT to terminal (192.168.4.10)
2; Terminal can ARP /a and see server;
CANNOT ping, connect, etc server.
I later noticed that when I try to enter the Windows directory from server to terminal, access denied.
I get prompted for the GUEST password.. guest had no password on the terminal, or server.
I even tried giving guest a password on terminal. Still wouldn't take it.
Both computers logged in with the exact same administrator password. I recreated them, made brand new ones, even unshared/reshared drives.
I deleted all previous mappings, and had it "map using username" administrator.
All subnets the same.
Like I said, you can ARP /a and see the terminal sitting there. You can also ARP /a from the terminal and SEE the server. But you cant ping/map/anything FROM terminal to server.
This sounds like the common XP home networking issue.. But I wanted to get more advice before I tell the customer to throw on Pro/2k and call me back.
It's connecting through a 3com managed switch. I'm not allowed to modify this, it's not our equipment. I had the customer take system off of this and run it directly through a small dumb hub, same issues.
Thanks!
edit: also made sure all Sp2 firewalls are off.
Thanks!
