One of my XP machines is crashing intermittently. When it blue screens, a blue screen with error appears for a split second but then the system restarts. Nothing appears in the event log regarding the incident -- I suspect that the event log isn't able to be written.
Is there another place to look for a dump? How can I make the blue screen wait for reboot (which I thought it did by default)?
The actual problem: some intensive tasks trigger it quite reliably (defrag, burning cds, loading games) but not others (such as benchmarking tools, copying files btw disks, etc). All temps and voltages are within limits. The suspicious thing is that CPU load is consistently 20-30% without any process obviously consuming that cpu in task manager (cpu speed isn't the issue either).
