XP-90 Package problems.
thebliX
Ok so I recieved my package last night (xp-90, 3200 Winchester, Asus a8n-sli deluxe Sapphire x800xt pci-e) last night from NCIX (Canadian etailer) and I was just putting everything together and was reading the instructions for the XP-90and noticed 3 things. 1 fin on the heatsink is bent. Dont know if this is supposed to be this way but it is. Also there were no screws included. And the white/blue fan silencer things it was supposed to come with were not there. Now either I dont know where to look (took the cardboard it came in apart) or it just didnt come with it.
Now I was wondering if I should RMA this back to them.
If you have this heatsink could you tell me where the screws/white/blue fan silencers were?
Thanks
There is a plastic baggy that holds that stuff (at least with my XP-120). I heard someone else got an XP-120 and was missing that baggy. If you checked all your stuff without ripping it open like a kid on christmas, and it's nowhere to be found, I'd call the e-tailer and see what they can do.
Well I pulled a little boy on christmas style, but I kept everything inthe same area, and its no where there. There was no baggy. Just the thermalpaste shoved in the cardboard and the fan clips on the side of the cardboard. I guess I'll have to give em a call.
there is no screws for xp-90...
the fan silencers were two silicon strips that of the size dimension of 90x1x1mm
and it is clear white in colour... it comes in one small bag...
also it comes with one K8 bracket
