I'm looking to buy an XP-90 for an AMD Athlon64 3200+ and I was wondering if it needs a cooling fan or is that optional? If so, which fan do you recommend.
I have the 92mm panaflow and my temps were idle 32c before I overclocked. With 1.55 volts my cpu is still holding strong with 35c @ idle. I also have great airflow though.
I bought a 90mm thermaltake 4000rpm fan, it came with a manual knob for speed or temp sensor. It also lights up blue but the point for me was more cfm.. It works real good on my xp-90.
guys, report load temps, idle temps dont mean a heck of alot. John, I used to have a 90mm CAT and then I got a panaflo. What a world of difference, same airflow, even quieter, one of the best $8 I've ever spent.
