XP 64bit not using all 4gigs
JiBB
Ok this is slightly over my head and I'm curious if anyone can help me out.
I currently am currently running a 64bit version of windows for my work applications. Maya, Photoshop, After Effects etc. I have 4 gigs of ram available but I'm constantly running into an error saying that windows is out of virtual memory and needs to increase it. However I still have atleast a gig of RAM free when I am prompted with this message. So as a result of this my paging file on my hard drive is becoming rather fragmented.
I was wondering if anyone knows a way to force windows to make use of the extra gig before it goes looking for more virtual mem. Any help would be great.
I'm not sure how having one GB of free memory translates into a fragmented pagefile, but I don't think that's leading down the road of a solution. How do you currently have your pagefile configured?
Ah, that's a good point. If I understand it correctly, if those apps are the x86 versions, they can only use 2 GB of memory. If one of your apps has a memory leak of some kind, you could run out quickly.
if I understand correctly, if they are 32bit versions, they run under wow64, which emulates a 32 bit environment, which comes with a maximum of 2gb address space, period. 32bit apps CAN address more than 2gb if they are compiled appropriately, but XP64 will not give you more than 2gb for a 32bit app regardless.
yeah that's probably it. Maya is a 64 bit version but photoshop/all adobe products are not. I'm still not sure why they haven't jumped on that bandwaggon yet.
Just for reference I have my paging file set at min 2gigs max 4gigs.
Thanks for the help. I'm guessing the only thing I can do now is wait till Adobe gets with the times.
Does that mean that each 32-bit program has the potential to run in their own 2GB space, or is 2GB the limit for all the 32-bit programs that are running?
You can try the /3gb boot.ini switch. It can help some applications, but may cause problems with others.
Did you manually change your virtual memory settings? Something is definitely wrong if you're getting VM errors and you have available HD space.
Each application can grow to 2 GB. If they have the largeaddressaware bit set in their image header, they can grow to 4 GB.
the /3GB switch is only valid in the 32-bit editions
