XP 4gb memory?
Devonshire
I heard that xp 32 bit doesnt recognize, 4gb of rams.
I also read somewhere that there is a way around that by changing a sys file or something.
does anyone know??
Operating System Support. The PAE kernel is not enabled by default for systems that can support more than 4 GB of RAM.
To boot the system and utilize PAE memory, the /PAE switch must be added to the corresponding entry in the Boot.ini file. If a problem should arise, Safe Mode may be used, which causes the system to boot using the normal kernel (support for only 4 GB of RAM) even if the /PAE switch is part of the Boot.ini file.
