XP 32 / 64 and Conroe OC
NickM
I noticed in the OC database that no one was running 64 bit XP-is there areason for that? Does 64 not overclock as stabley?
(25) You are allowed one signature per post. A signature section is supplied for that usage. No one wants to see your name on your posts multiple times as it is annoying.
I've ran various Linux installs using 64 bit and haven't had any problems with my overclock.
The same for Windows XP 64 when it was installed. :)
I've got a 6600 running at 3180 under XP 64. My mobo (Abit QuadGT) gave me more issues than the OS did.
One advantage is being able to use all 4 gigs of my ram (instead of 3.4Gb or so under XP 32)
Thx for the replies guys. Planned on running 64, even though I only will start with two Gigs at this point.
