Major_A said:When's the last time you installed chipset drivers or more specifically AGP GART drivers?
Tytanium said:Umm...did you try "fps_max 999"? If somehow your HL2 got to be set at "fps_max 31" that could definitely be causing a problem...
Also, check your refresh rates on your monitor, and make sure they're set as high as the monitor will let you.
tsuehpsyde said:That has to be the strangest problem yet....do all ur games do this or just HL2? If just HL2, email valve and ask![]()
