xp-120
Nolemiah
would a thermalright xp-120 work on a socket 939 3500+ on an asus a8v? thanks!
from what i understand, the xp-120 will fit on the a8v just fine, unless you decide to upgrade the chipset cooler. then, itll be a bit more difficult to install either, but i hear its still doable
i dont believe the caps get in the way for the installation of the xp-120, and if it does, it can still be installedw ith slight bending
