XP-120 or XP-90?
No, you guys kinda threadjacked it into soemthing about lapping XP-120s... only 2 guys actually responded and im seeing if i can get more responses on this and other forums...
What has your personal experience been Burner?
Personally, I'll be using the XP-90 on my new comp in October - I just feel like its more practical than the huge XP-120. Also, from reading reviews, it didn't seem like the XP-120 did THAT much better at cooling, it was just a little more quiet.
Going from an SP94 to an XP90 and dropping 4c off idle and load. I'd say it's great! Plus I don't have to worry about all that weight coming crashing down on my CPU. Not that it would happen.
What kind of fan? The one i listed is like 55cfm at 35 dba, but it has a lot of pressure
It's a Panaflo with those same specs
I recommend the XP-120, if you have the room. My temps dropped 10deg from stock cooler and 5deg from my theraltake silent boost.
